progress...and a poll of sorts
The rate of progress has slowed, mainly due to lack of funds - I've had to use "hot rod time" to make money also
Time is rather short as it is, but things are looking up. One of the current issues is what engine to use for this project.
I have several options, partly dictated by my desire to use a 5-speed stick, and the fact that all I have are NWC T-5 transmissions, which puts a limit on the torque I can put through it. I'd like to use an odd-ball engine, but one that has respectable power.
Lately, I've decided to transform my daily beater into a street/strip terror, so that takes the 455 Olds out of play.
Here are my current engine options ( I can post pics later of some of them) in no particular order:
(1) '66 Buick 340 V8 - only built for 2 years, looks different than later Buick V8s. It's a 2-bbl engine ( 9:1 compression) but I have a 4-bbl intake and the parts to put it together. I'd need to get a stick flywheel, though. Looks bigger than it is - has a tall deck.
(2) 403 Olds (or maybe a 350 Olds) - I have most of the parts - hot cam, fresh heads, Performer RPM intake, etc. but the 403 short block is worn out (kinda usable) or I'd have to mix 'n' match parts + buy rings & bearings to piece together a 350 short block.
(3) Cadillac 4100 V8, FWD version - very odd ball, but small displacement (250 cubes) - it is a GM reman, ran when pulled. Aluminum block, iron heads. Would have people guessing, but rated at 150 HP stock, with few aftermarket parts available. Easy conversion to carb + HEI though. T5 5 speed can mate to it - I have the bellhousing.
(4) All aluminum Olds V8 - another small-cube powerplant - the heads are off mine, so I'd have to buy parts to at least reassemble it; disadvantage is that it has a weird bellhousing pattern, and I only have the baby Slim-Jim auto for it.
(5) Taurus SHO V6 - we have the complete engine and harness, but would need to scrounge up a Ranger 5-speed and some parts to make it work. 220 HP, wild looking, for sure.
(6) I can get a running '89 EFI 3.8 Buick (FWD) V6 with harness and ECU, and I have a factory supercharger setup off a '93. Would take some work, but would definitely be different.
What do you all think??
No matter what engine I choose, I have a 3.90 geared O rear that will even turn the Cad V8 into somewhat of a hero, and overdrive is definitely in the plan.
440shorty
P.S. It would figure that I have the smallest displacement Cad engine ever made.
