rainman
Rough Rodder
Very nice work, keep em comming!!!
looks great, about the hubs, if you can get some bushings machine,you would be able to use some other hubs.I am using bushings to put buick hubs with the aluminum finned drums right on the ford spindles.
I noticed your tie rod is very close to the top of frame, now if your front axle tilts up on one side , and it will , when your on an uneven incline, the tie rod will bind on frame , that was a problem I ran into when I mounted my axle the first time. so I had to redo mine ...lovin the build...keep at her..[dr[dr
That is some serious fab work! Hats off to you. Yeah - is this gonna be the only hot rod there?
