Moving right along
Hey fellows:
I'm back and have made a bit more progress on my project.
Since I made the shock mounts I finally got to the tougher stuff, the swing pedals and throttle pedal. I used an old Ansen swing pedal assembly, that my friend didn't want, to start with. Because I was using the clutch/brake master cylinder from a 60's GMC/Chev pickup I had to narrow the pedal assembly to accommodate.
I did this by taking some out of the middle of the assembly. It worked well but was a pain. Next I made a 10 gauge metal plate as a doubler for inside the firewall for strength. That stuff is hard to bend without a brake.
After bolting the doubler to the firewall I located, with help from my friend, the pedal assembly on the firewall. Locating the mounting and master cylinder clearance holes come next. After that I drilled and hole sawed the necessary holes. We cleaned up the holes and mounted the pedals and master cylinder. Now the hard stuff,
we had to highly modify the pedals for foot clearance and operation. We cut, flipped around, extended, bent and cursed until they worked.
I thought the clutch/ brakes pedals were hard until the throttle pedal came up. I wanted the spoon pedal and no cable look so man did we do some finagling. I also had to bash in the tunnel for clearance
for which I will eventually make a nice piece to weld in place. I also finished up mounting and sorting out the steering box and linkage. I used a 46' Dodge pickup steering box, 35'-40' Ford tie rod and drag link, no mods. The pitman arm is also the same year Ford, heated and bent in the opposite direction to fit the tapered splines of the box. I believe the geometry is fine my, only problem is steering radius and Ackerman are not great but I shall see. I had to make new steering stops so the tires would not hit the wishbones. I might reverse the front wheels later. As you can see I mounted my headlights. I used a Model "A" headlight bar cut and bent to fit around the grill shell. I "got" the headlights from a COE cab along the side of the road "somewhere" in California. I'm not sure of the year but it was GM. I had to rebuild them because they were all rusted out. They are like Guide 682-C's and they had been there for years. Well I know this is hard to follow unlike other guys builds but thanks for looking. Guys keep moving forward on your projects. Driving will be fun. Steve
