agdeuce
Thanks guys
I have been working until past midnight for the last four days. I have the tail end all wired. The under dash wiring is from the Corvair and it is modified and installed. The headlight wiring is run and the turn signal is switch is ready get hooked up. I should have the wiring done this week and I hope to fire the motor this weekend.[dr I have to bleed all the hydraulics first. The darn pinion seal leaks like it isn't even there.
I will have to put a new one in soon or all that expensive gear oil is going to be wasted. I need to mount the battery box it goes in the tool box (Army footlocker) in the bed. It is coming along. I need to get some sleep. Thanks again for following along on this deal it has been a "long time a coming". More later. Steve
