MercuryMac
Builder Junky!
Hi agdeuce A while back you were having hydraulic clutch problems, so it brought back memories of quite a few of those horrible clutch linkage set-ups. I've hated hydraulic clutches since the 70's when I started using them. Anyhow, Good work, you are done ahead of me and out there enjoying the fruits of your labour. Happy cruisin'.
Extreme, a note to you, your '38 cab will probably be 2" higher than our '36's. When I started out building I had no drivers door, so I measured other doors and the 1947 Ford drivers door was the right width but too high. There is a guy on here somewhere that has a white '38 cab with '42-'47 doors on it or the other way around, anyhow, I think the '38 to '47 doors interchange. So, to be cool you'll have to chop your cab. [ddd
