jmlcolorado
Cant say i dont learn something new every day:
"Carburetor
There are two types of choices in a carburetor turbo setup: “Suck-through” or “Blow through”.
The Suck-through (or draw through) setup involves mounting the carburetor before the turbo inlet (usually in front of the impeller mouth). This means that both fuel and air are drawn into the turbo already mixed and then blown into the inlet manifold. This is by far the simplest way to set up a turbo, as the carburetor doesn’t need to be especially modified and tuning is quite easy. The main disadvantages are that you can’t use any intercooling with such a setup, as it is dangerous to run air/fuel mixture through an intercooler core. The reason for this is that fuel can condense inside the intercooler core and stay there – if you then have an engine backfire the intercooler can explode. As a result water injection is about the only option for cooling the charge air with this setup. This also corresponds to a blow-off valve because instead of just venting pressurised air, it would be releasing a fuel/air mixture which is very dangerous.
The Blow-through arrangement, logically enough, means the carburetor is mounted after the turbo compressor, so the turbo only draws in air and then blows it through the carburettor, which adds the fuel. To use a carburetor this way it has to be specially modified so that the jets will still add the right amount of fuel. This means specially sealing the carburetor and pressurizing the fuel bowls to match the turbo boost. The good thing is than an intercooler and also a blow-off valve can be used with such a setup."
"Carburetor
