Yankee Transplant
He started out with nothing, he still has most of
am I reading this meter right ? I have a charging problem with my mower and it says to read the ohms on the armature pin ,, ok ? does this mean you stick one lead on the pin and the other to ground or what ? its not clear , I guess they think they were talking to people that new what they were doing Its supposed to read 0.00 or 0.01 and it will be good ..
this is an ohm meter right ? if right do I have it on the right setting ?[S I put one lead on ground and the other on the pin and it read 0.00 on both pins .. if this is the meter i;m supposed to use .
