RAT FINK
Either way you do this ,dropping into the cowl,cutting or sandblasting like what was mentioned also they will all work....but which ever way you decide...do this prior to chopping...as the roof is lowered it comes out of proportion with the body and will have to be cut and widened both ways to fit properly....measure lots to make sure it will work out...make a paper cut out of your windshield and slide it down your windshield to your desired chop...you will notice the angles change greatly...this is a big undertaking measure twice cut once...then say oh..crap!....if you are going to sand balst it which works well...leave a 1/4 in or so and have a glass shop belt sand the edge to finsh it...Good Luck![
