Nice progress! [P[P[P[P
They aren't perfect by any means but neither is the car.
...and tried to tighten up some air leaks in my air valve. I'm really having a hard time getting the leaks to stop using the copper tubing. It is hard to work with in the tight space. I may end up using plastic air lines coming out the back of the valve body then adapt to copper. Anybody successfully adapted plastic to copper?
I used ferrule fittings. I'll look at getting push in fittings for plastic tubing then adaptors to the copper. Hopefully that will help. Thanks!
Thank you all for the input, I appreciate it. So what I'm hearing is...get rid of the copper air lines and just go to air line specific plastic tubing? I really like the look of the copper but you guys are absolutely correct, it is a safety issue. I don't want to loose air pressure cruising down the road! Or is there a safe way to use copper?
