Yankee Transplant
He started out with nothing, he still has most of
good luck ... my cab already had a big dent in the roof , a few dings here and there, so it didnt match perfect after I cut it . but , I used 2 pieces of 1/2 inch all thread and 2 pieces of angle iron I took the doors off and bolted the angle or you can tack it to the front and the back of the door frame (Inside cab) then stuck the all thread threw some holes I put in the top and bottom of angle .. I adjusted the cab back together this way ,,and it held it sturdy enough to get measurements on the rest too. But mine is a (block truck ) looks good a block away
