Willowbilly3
A *real* tin magnet
I haven't post any pictures for a while. Here is my steering column mock up. It is a tilt/tele of my own design. I used the slider from the Astrovan shaft to make my telescoping part. The part the steering wheel bolts to was made by a friend on his lath, it will get a final smoothing. Since the dash supports the outer end of the shaft it needed quite a bit of bracing.
