Blocks are not the best way to lower it is what I was referring to.
Go with the axle on top of the leafs then you can use lowering blocks. It's not the best way to do it but it's the quickest and easiest.
Why not? Yes, they can put the axle further away from the springs which creates a bigger lever arm, but I've never had issues.
A windshield can be made from lexan. NOT PLEXIGLASS!
The most important thing IMO is to just stick with a plan. Create small goals and stick with them before moving onto the next step. It helps keep you motivated when you can see the small steps of progress. When you jump around it can make you over whelmed.
I was just looking up some sizes, thickness and prices online. Looks like pretty much any hardware/home improvement store has sheets. Even saw where Grassroots Motorsports made their own windows for the Miata, so looks like it should be easy to get over this hurdle. They said it was easy to cut and form and mount. Sounds good to me!
We tried to make a plexiglass windshield for an IROC Camaro once, and it was almost a complete failure. As much as we tried heating and bending, it cracked in the upper corner, but did what it had to for the short time we ran that car. Long story, but it was a real PIECE !!! Someone else's cobbling that I inherited and then sold away. Far FAR away...
To further what 21Willys said, a windshield should never be plexiglass. Plexiglass shatters on impact, where lexan does not (and is actually quite impact resistant).
I don't think either one is legal, windshields are supposed to be laminated safety glass.
Exactly. Why would you waste time effort and money on lexan when you can just source a replacement windshield? International used that same windshield for 10 years and they certainly aren't rare. Do some looking around.
Thinkin'.......and simplifyin', that's the ticket.![]()
