I am building a model A frame from scratch and using original front and rear crossmembers. I am extending the frame to better support the pickup box, so the rear crossmember is not going to be fastened to the rear of the frame. I have Z'd the back of the frame from behind the cab 4" and I am running the frame rails parallel going back.
I am trying to figure out how to mount the rear crossmember. Is there any reason to leave the outside ends on it, or can I cut them off and mount the crossmember between the frame rails? I am channeling the cab but not the box.
