MercuryMac
Builder Junky!
Like Skip, I was envisioning wisps of smoke and liking the idea. So much so that I was already thinking of stealing your concept, Don. I'll have to practice a wee bit so I don't get just a 'Dalmation' effect, though.
I like the idea, but not your example so much.
I poked around a little and found this...
I can imagine something of the kind, in the outlined areas below...
The good Doctor's example is way closer to what I was thinking of. Tone it down by about 50% and I could start to like it. [cl
I absolutely agree. And I suspect that I will like it once its done.If you tone it down that much, is there much point in doing it? I mean I like subtle, I just think in this case you need to strike a balance between "been in a fire" and "nicotine ceiling".
That looks sorta like the way I would do wood back when I did some woodworking for a hobby. Singe it with a propane torch, lightly sand it just enough to make it smooth and leave some burn marks in the lower parts, then varnish the heck out of it. Would really make a grain pop out.
It was mandatory in the 60s & 70s wasn't it?I use a propane torch on a lot of my wood projects before staining. It really brings out the grain and character in the wood.
Looks great.[cl
Very clean wiring.![]()
[P [P [P
Great progress. [P[P
Looks really clean Don, it's obvious how much you like doing the wiring. My only comment, and please forgive me for sounding critical - are you sure you want the gas line inside the firewall? Fuel leaks don't happen very often, but if one ever does...
Right you are Don! After I commented I thought, my Graham has the fuel cell right behind the seats, with only a plywood panel closing it off from the passenger compartment...but it's also on the "non pressure side" of the fuel system. Thanks for posting all your updates, your progress is amazing.
Thanks, Bill. Yep, these things are not like a 2019 Lexus, with crumple zones, and all those safety features. No matter how well we build them, they are marginally safe, at best.
BTW, I used to have a fire extinguisher screwed to the kick panel of my 27, but people kept stealing it when I parked the car at a restaurant or some other place. I'd like to put one in this car, but I think I will put it in the bed, hidden by the louvered tonneau cover.
I do have a fire extinguisher screwed to the back seat delete in my Mustang, and it does give you some sense of security in case of a fire.
