[cl
[P [P [P
[P [P [P
How are you mount the tank to the frame?
We then transferred that dimension to the cut off top portion of the shaft and Dan cut it to the right length and tig welded it on. He first cut up a grade 8 bolt and slipped it inside so the weld would penetrate that bolt, then he ground it smooth and slipped a tight fitting sleeve over the welded area and welded that sleeve for added strength.
I have to say seeing the rusty patina on the body in these pix warms my heart.![]()
The excellent craftsmanship always seen in your work does as well of course. So good to see this one finally moving ahead Don.
