BigIrish
Exactly. I've heard of people using these on more modern cars and supposedly they work for them. I don't think its strong enough to pull fluild from a low m.c. like in mine though.
Took a break from the floor and made an air cleaner out of the orig air cleaner housing and a Ford-style "V8" hubcab. Basically cut the center section out of the old air cleaner housing. Welded the wingnut to the top of the lid. Then cut most of the lip off of the hubcap, leaving 3 little tabs which I poked through the lid, then welded up from the bottom. Looks pretty cool I suppose and price was right!
Got the steering all done. Mounted my '50 F-1 box and sliced the orig drag link to the new one. Fabbed up two shaft supports on the inside and installed the quick-release steering wheel hub. Works nicely.
So theoretically, she steers, stops and will move in a forward motion. Need a gas tank and gas pedal and I'm ready for a spin.
Oh ye of little faith!
Kidding - it does look a little tight from those pics, but I have quite a bit of clearance actually....
