Yep, it is a good product, and we are looking at it and another product , Raptor bed lining spray. If you thin down the bed liner it comes out pretty smooth but with a nice texture. Plus, it is as tough as nails, being designed to hold up in truck beds.
Today we worked on the mount for the seat back. I am going to run a solid seat back that spans most of the width of the body, and am making it out of Starboard and I will have it rolled and pleated by the upholstery shop near my shop.
We looked at a lot of ways of fastening the top of that back to the body, and finally came up with a simple set of brackets that we fabricated. One part bolts to the body and the other part bolts to the back rest. To install the back rest you simply drop the one part down into two pockets on the part mounted to the body, and then insert a couple of bolts at the bottom to hold that panel in place.
Tomorrow night all we have to do is cut and fit the Starboard back rest to the brackets we made tonight and we will be done with the entire seat setup. Then I can run the body down to the upholstery shop and have them make up the foam padding and rolled and pleated upholstery.
Here are some pictures of the seat mounts we made tonight. Now I can get them painted and also paint the interior of the body with whatever I decide to use on it.
