So if I have 6" from the rim to ground then were should I put my frame. I know the chances are slim to have 2 front flats,but If I have one how much would that corner drop?
Are you Z-ing your frame?
Uh...probably about 6". If you stretch a string from the bottom of a rim of one tire to the contact patch of the other three tires, nothing should below that string or it will scrub in a blow out. Do it with all 4 tires. Extend the string past the 'flat tire' to make sure your bumper, etc. wouldn't hit ground if need be.
Exhaust is optional.
I wouldn't want a straight axle below the edges of the rims at all.
KEEP IN MIND: Just because it's above the scrub line for a flat on level ground, it might still get hung up going into a parking lot!
