05snopro440
ZZ that frame looks flipping awesome! Is that powder coat or paint?
It's still in bare steel
Great looking Frame!!![cl[P
I like the panhard bar design. Why didn't I think of thank?[S[S
Are you going to run a blower on your engine? I noticed the lower belt drive on the crank.
Makes perfect sense to me.
That's some awesome looking work ZZ....very nice.
The more I look at your frame the more I worry about needing some more bracing on the frame rails from the kick up to the trans area.
Do you think I really need it? The engine builder told me my motor is built for 600 HP but I think he might have been exaggerating.
If I do... could the additional set of parallel rails run outside the frame versus inside? I could follow my cab sill lines. I'll attach a picture to refresh your mind.
Sorry....just realized this is on your thread not mine
Thanks
If it were mine, I'd add something to the structure, it's a long stretch between the rear and front crossmember. I also like to use a crossmember under the engine mounts connecting the rails too for this reason. Not sure if running outside the rails would work right....might look goofy too.... Are you running any exhaust underneath or just lakes pipes? On my Rat55 build, I used the space under the cab outside of the rails for exhaust to run through.
Nice job on the wishbone [cl
PS: That high pitched squeal might be the result of that sucking vacuum leak coming from your wallet!!!
