fuzz
Livin' the rat roddin' lifestyle
This is brake kit #31933........first I want to rant that no installation instructions are included. This kit has GM metric rear disc brke calipers that are supposed to be 78 and later [unknown what model cars the fit cuz speedway don't tell ] I assembled the rotors and the mount bracket on the caliper and began to fit them to my rear trying to determine the location of the bracket to weld it the rear. I pulled the emergency brake lever to the full on position but the brake pads don't contact the rotors. As if the rotors are too thin. The e-brake lever is mechanical so no fluid in the caliper should make no difference. In the picture you can see the the e-brake lever is keyed to its shaft so I moved it one flat, still won't hit the rotors.
My question is if I continue to rotate the lever another flat so it will push the piston out further will I eventually go too far and have a fluid leak around the piston. You can see far out the piston is comming in the picture I think. [speedway tech is closed on weekends of course]
