DozerII
So maybe a stupid question, I have a 1975 Chev Caprice as a donor car for my build. Can I mount the power steering box rotated 90 degrees to give me a front to rear, as opposed to left to right movement?[S
depends on which way the arm goes/ You have to imagine it installed and see if the arm will rotate the right way or if it will have reversed steering.
Physically mounting the box on it's side won't make it leak or aything like that. that's okay.
if it goes the wrong way use a steering box that has the arm mounted backwards from yours... the screw inside will twist the opposite way.
