Davidhud29
This is where I stopped to think if this is really what I want to do.
Aren't you supposed to figure that before you cut it all up?
Nah, I just wing it.
It may not be completely hidden, but I think you have done a great job at trying to hide it. Once everyting is mounted engine and such you will berely notice it like that down there, unless i missed that it needs to come up more yet...
glad to see another update....i think that it will look ok when its all assembled.....
i find many times i worry away at something that is relatively "invisible" when the project is complete....
Do you have the length to allow a machined arm to go in there that would use a more traditional tie rod end at the connection to the hub as well at the rack? I assume you would need almost full movement in all directions at both connection points... hopefully that makes some sort of sense.
Flipper I wonder if you could find dust caps from motorcycle forks the right diameter to fit the rack ends? They would be less intrusive if you could. But it would have to be a small bike.
Shoot us a pic maybe together we could come up with something. Do the teeth lay upwards, towards the back front or down?
On the drivers side the teeth on the rack exit the housing when you turn left. If you are talking about what I think you are, it wouldn't keep stuff out of the teeth.
Got pictures of that you are thinking about?
