Skip
I've been watching Bad Chad build his latest project, and almost had myself convinced to buy a plasma cutter. But, the good ones are more than I can justify, and the cheap ones are, well, cheap. So, the other thing Chad was using the heck out of was his throatless shear. They are only a little over a hundred bucks at HF, so I decided to treat myself. Used the 10% discount that is almost always available. Got it home and put it together, cleaned it up, and realized that it needed fixin' right out of the box. So, I added a return spring. A couple scraps of angle iron, a spring from the junk drawer, and a little cutting and grinding and now the thing works much better, and keeps the handle up out of the way when not in use. The new upgrades do not get in the way of using the tool. A stand for it will happen as soon as I can get to some materials.
