TiredIronGRB's '30 Model A Coupe
Almost a roller...
I've been looking at headlight stands and would like to make something myself but still stay with a traditional theme. I thought what would I do if I were a young man in the mid to late sixties...I would use what was handy, so I started looking around the shop and came up with this.
The arms off the '48 spindles, eyes off an old set of shocks and two .250 thick spacers (not shown).
There's the spacers, welded in flush with the bottom of the shock eye.
Sweet build!! I'm impatiently waiting for the rest of the build.:DWhat kinda wagon you got ur talkin off sellin???
I got my rear axle this morning, it's a Dana 44 from an International (58" wide, 5 on 5.5" lug pattern). I cut all the brackets off and mocked it up with a simulated load on it ("C" clamped the spring to the crossmember), should work good with the "T" spring.
I cut the lip loose on the center crossmember and moved it up, I will cut out the hang through for more trans clearance.
Picked up two nice wheels for the rear.
Also got a nice steering column, box and wheel from a '40 Ford truck. Steering wheel is perfect with no cracks and has all the button hardware.
She's almost rolling.
Got my radiator and grill in, I went with the reproduction grill and shell...I just couldn't see three times the money for an original. The fit and finish are surprisingly good.
