Old Iron
If I rejet the 390's down, will they work sufficiently?? I realize this tunnel ram set up is mostly for looks and I really do like the way they look however, not bein a mechanic, I don't wanna compromise reliability and performance just cause they look cool.....but I really do like they way it looks......Oh...did I say that already??
I do have an Edelbrock Performer intake (Single carb) that I can use and will if it really will make that much more of a difference. If I do go back to a single carb, using a mild thmpr cam, what size would be good for performance and reliability?
Man, if you want to run a tunnel ram then, by all means do so. It's your ride and the only person you have to satisfy is YOU.
Put it all together and then start tuning. If you don't like the setup, you can always change it.
If you change later and the Performer intake is not an Edelbrock Air Gap then, try to get one. With the Comp Cams h268ex, the Air Gap intake and a 650 Holley you'll be surprised at the performance and relatively good economy.
I too understand the Thumper cams are not that great. Hear say!!!
Best cam I ever had was a 290 Lunati solid lift. Hardly ever had to set the tappets.
