V8 Bug Build..Now with working Photos!
Ben Modified
Oct 24, 2015
387
So the photo site that I have been using is no longer and my photo links no longer work......so I am reposting the photos in bulk here.
[/url]20141216_164959 by Ben Modified, on Flickr[/IMG]
[/url]20160114_174332 by Ben Modified, on Flickr[/IMG]
New firewall
[/url]IMAG0592 by Ben Modified, on Flickr[/IMG]
[/url]IMAG0591 by Ben Modified, on Flickr[/IMG]
[/url]IMAG0594 by Ben Modified, on Flickr[/IMG]
[/url]IMAG0596 by Ben Modified, on Flickr[/IMG]
[/url]IMAG0612 by Ben Modified, on Flickr[/IMG]
[/url]20160713_164753 by Ben Modified, on Flickr[/IMG]
[/url]20160713_164823 by Ben Modified, on Flickr[/IMG]
[/url]20160720_150040 by Ben Modified, on Flickr[/IMG]
http://www.BenModified.com
Fought with the clutch slave cylinder today, but finally got it in. The cylinder is off a jeep cj5. It fit nicely next to the oil filter on the chevy V8 but the filter must be removed to get the bolts in. Bolted it up only to find that the filter was making contact with the bolt heads and would not screw on. Solved the problem with these button head bolts.
[/url]20160811_101808 by Ben Modified, on Flickr[/IMG]
[/url]20160811_101921 by Ben Modified, on Flickr[/IMG]
Prior to installing the hydraulic line to the clutch, I sleeved it with some heat shield.
[/url]20160811_110427 by Ben Modified, on Flickr[/IMG]
I am re-purposed the back bone from the original vw pan. The section was originally fully enclosed but I have cut out the bottom panel and am using it as a driveshaft tunnel.
[/url]20160811_105725 by Ben Modified, on Flickr[/IMG]
Driveshaft is installed. Fit very well.
[/url]20160819_140109 by Ben Modified, on Flickr[/IMG]
Also got a set of headers for a very good price that I had ordered a while back. They do give me more clearance around the master cylinder, so no insulating wrap needed, but I really like the look of the roadster headers
[/url]20160819_140119 by Ben Modified, on Flickr[/IMG]
[/url]20160819_140143 by Ben Modified, on Flickr[/IMG]
For comparison
[/url]20160815_150838 by Ben Modified, on Flickr[/IMG]
Like. [cl
Saw a rolling bug shell on CL today for $500. I was tempted.
Instead, I actually went out and worked on my 39. :eek:
Pulled the bug body off today to clean up a few things
[/url]20160827_141508 by Ben Modified, on Flickr[/IMG]
Ran a tap thru all the body mount threads
[/url]20160827_145826 by Ben Modified, on Flickr[/IMG]
Applied a thick bead of silicone and bolted down the body.
[/url]20160827_165610 by Ben Modified, on Flickr[/IMG]
Next, re-install the doors to make sure the the body is square prior to building a roll cage for it.
[/url]20160827_172445 by Ben Modified, on Flickr[/IMG]
Doing the rust repairs on the doors before bolting them back on. The passenger side was not too bad, but the drivers will need new metal at the bottom. I used something called Strong Steel Stik from LPS to patch the better door as well as some pin holes around the side rear windows. I decided to try the product due to the fact the the previous owner had filled every opening in the sheet metal with expanding spray foam. This was the main reason for getting the body sand blasted, but unfortunately, some of the foam remains. So in these areas, to avoid starting a fire or creating toxic fumes, I am filling in with steel stik, instead of welding.
Seems to work well. The large patch at the rear can be welded in.
[/url]20160831_130859 by Ben Modified, on Flickr[/IMG]
[/url]20160831_130852 by Ben Modified, on Flickr[/IMG]
[/url]20160831_150126 by Ben Modified, on Flickr[/IMG]
I will need to make up a patch panel for this area as well as the supporting metal underneath.
[/url]20160831_150138 by Ben Modified, on Flickr[/IMG]
[/url]20160831_150243 by Ben Modified, on Flickr[/IMG]
Hi Ben. Any plans yet on cooling, radiator, and grill shell, etc. I like your hair pins and front attachment fab work. Thanks again for all the details.
Here is a photo of the radiator installed...prior to the trip to the sandblaster.
[/url]IMAG0670 by Ben Modified, on Flickr[/IMG]
It sits up above the thermostat, at a severe angle, to fit under the stock hood. It also requires a filler neck in the upper hose at the high spot of the cooling system. I plan on using a hole saw and dimple die to open up the front of the hood for cooling or possibly some sort of outrageous scoop/nozzle.
The kit car that supplied this frame also supplied the engine and radiator. The previous owner claimed that this radiator kept the motor at a cool 180 degrees, but I find that hard to believe. I have a larger radiator that fits the larger space available in the bug. The kit body positioned the radiator lower and more up right, but I don't see any issues with the new location. If more cooling is required, there is more room available under the stock deck lid
[/url]20160811_114808 by Ben Modified, on Flickr[/IMG]
I can't take credit for the hairpins or front end. These were all part of the remains of the kit car chassis.
