Oldboy
Hello,
First a bit of history. While my ford 9 inch was out for rebuilding, I did two things:
I had a different gear set installed. I changed from 3:01 to a 3.50. And while the axle was out I added. 1 1/2 lowering blocks .
Now i have a noticable vibration at certain speeds. It is only slight, but it is there.The local driveshaft buillder says that i have changed the angle and possibly "pulled" the driveshaft further out of the tail of the transmission.
Does any of this make sense? Does it sound logical? Can i adjust the pinion angle?
Additionally, while the gearing makes for more fun, i am on now wanting a 4 th gear, currently running a gm turbo 400.
thanks for any feedback. Russ
