thanks sno, I have a couple plastic sticks I made from an old lawnmower cover, they work great!
IMG_2218 by
Joe Doh, on Flickr
I also have a flat hook I fashioned from an old screwdriver, it helps moving the rubber lip over the seam. this windshield rubber was still a major payne, the last one almost fell in. but this one looks better too, so six of one, half dozen of the other.
installed the wiper motor and shortened the pass wiper arm 3/4". if you are using a newport wiper motor you will need to do this too. the instructions say to "bend the arms" if something binds, but the passenger arm is just too long, bending will just make it harder to attach.
56356941504__6D44F9AC-47D5-4BE8-BB28-A556288D17F7 by
Joe Doh, on Flickr
IMG_2208 by
Joe Doh, on Flickr
I am thinking if I am reading the wiring diagram of the s10 correctly, I can hook the motor up to the factory stalk.
more hood problems. the passenger side was in right but the drivers side was off, this is the accident side so likely needs adjusting from that anyway.
IMG_2205 by
Joe Doh, on Flickr
IMG_2204 by
Joe Doh, on Flickr
closer, still needs a little more..
IMG_2210 by
Joe Doh, on Flickr
well crud.
IMG_2212 by
Joe Doh, on Flickr
this will be the THIRD set of hood bolts I have bought, the first got lost in the shuffle when I came home with them, this set broke from repeated install/removal.
it was too late to get them so I installed the new passenger glass in the frame.
IMG_2213 by
Joe Doh, on Flickr
if you havent done this job, it involves a sledgehammer.
the glass fits in the channel in rubber set tape, sometimes you get lucky and the old tape stays in when you take out the broken glass, but its tighter than my wallet. some liberal tapping was needed to get the set screws back in.
then I switched out the passenger door trim for that stainless I got at the swap meet. looks good.
IMG_2215 by
Joe Doh, on Flickr
I put the new chrome door handle on after that and the door swung shut.
time to stop.
edit: powdercoat called and the tire shop was around the corner.
