howiess2000
Active member
I have a Lincoln 140 115v MIG, I'm using .25 wire CO2/Argon mix. This thing is rated to weld 1/4 inch, but I'm not able to fully penetrate 1/8" I saw in a previous post that a good ground and clean metal is essential, and I will make sure I have that, but do you have any other tips?
Thicker wire?
Slower or faster wire speed?
Flux core vs. solid wire and gas?
I saw some people post that a 115v should do the trick, so I'd like to see if I can use this welder to do my heavier welding, but if I have to go get a used 230v welder, then thats what I have to do.
BTW, I practiced with the fluxcore that came with the welder and I just got a tank of gas....what a difference!!
Thanx in advance.
Thicker wire?
Thanx in advance.
