I made some more progress on the kart. I got the push-pull cable shifter set up. I had it all tucked in nicely down lower where it was totally out of the way but then realized that the throw of the shift lever was totally ridiculous so I had to redo some thing and mount the cable end up much much closer to the shifter shaft on the motor. It'll work fine, I just have to get a little fancier with the floor in that spot. It's better to do that than have to move the lever 45 degrees to shift! I also got the brake and gas pedals mostly sorted out. Everything is still just tacked together so I can move things if I have to. The piece of pipe sticking out behind the gas pedal is an extension for the kick starter. I haven't finished that off yet but wanted to the the extension in to make sure that it didn't interfere with the gas pedal.
