Widen fenders or reduce rear wheel width?!
ok, this is going to sound a little weird but bear with me till the end.
Widen the fenders but do it on a angle. wider at the top than the bottom. Not much mind you but I think 1" difference would do it. Then set the fender on there so just the top of the tire is covered. you might have to open up the wheel opening a little so as the fender angles back in towards the bottom a little bit of the tire will show. That would give it a mean look without the rear fender being all bulky and fat looking. Just my $.02[;)
I am a fan of wider so here is a way to see if you like it wide . Make some brackets that will allow you to attach the fenders to the bed and try the new " look " out . Sit at a show /cruise nite etc and look at it for awhile and listen to the comments . If you don't like the way it looks or is received ,take em off . Not much lost in the process . You could even fill in the gap with a cardboard strip held in pace with that magic stuff called ducktape . I always cardboard and tape when I can . Really helps to visualise the finished product .
