Progress......
After struggling with the decision of what to use for outside mirrors I decided to use Jeep TJ mirrors.
They mount to a flat surface with 3 bolts. If you have a flat spot to mount to which I didn't so I had make one on the doors.
More cutting, welding and grinding. I used 1/4" plate and welded 5/16" nuts on the back side for a solid mount. Welded the plates in, smeared a little metal reinforced filler on to level things out and got the doors primed today.
Wednesday I'll spray the doors and finally be DONE with body work and paint.
