CR55
It's just a little surface rust!
yes. ...CR
The gauges are cool. The one thing I really don't like is that radio installation. Get rid of that plastic surround and do the same copper treatment like the gauges. Any exterior pics?
You might get a few 'don't care for it' type comments, but everyone here respects the build it like you want mantra.
I'd suggest figuring out where to put the fuse box and start with the engine systems.
ok. so the grease is residual from the engine that accumulated on top of the plug. what was happening was that the plug was not tight because it was the plug I took out to check for spark. so it was oozing because the pressure was coming out since it wasnt tight. anyway. skunked fuel was the cause of this mayhem. got the car started. but ran into another problem. the engine cranks now when the key is in the on position not the start. if that makes sense. so i insert the key turn it once and it begins to crank without me turning the key to the start position.
would it be the starter wired incorrectly or the ignition switch wired incorrectly?
well i got a lot of wiring done since the last time i posted here. The gauges are all in as well as the tranny lockup kit. the motor is all wired as well. so far its been fairly simple and only a few minor setbacks. i have everything connected to the panel but i want to start organizing the wires so that there not all over the place before i continue. if i just loop them together and zip tie them will it be a problem as far as having so much length of wire? i read somewhere that you don't want so much wire bundled up just enough to service the panel. would this affect voltage?
