kelseydum
Edited to say the box pictured is not a Mustang steering box.
There are several threads I've read through here, KB and other sites on traditional steering and setting either a mustang steering box (under the frame or upside down) or spending some serious dough on a reversed corvair box. I have access to several mustang boxes and a few Maverick and Comet boxes which seem to be identical to the Mustang box. I need a little help from those who have used the Mustang box in this way. I have 8" from the bottom of my frame to the ground at the lowest possible point. From the inside of the frame to the outside of my hairpins is about 5". If I were to mount the box under my frame the measurements say I can fit it in there. My question is how low will the box drop down from the bottom of the frame (I have 8" to the ground)?
Also, does drilling a hole in the side of the frame compromise the integrity of the frame if you patch all pre-existing holes? Here's a link to wht I'm talking about.
http://killbillet.com/showthread.php?t=2045&highlight=mustang+steering&page=3
Also, does the Mustang box need to be mounted at an angle like Grouchy's here... http://killbillet.com/showthread.php?t=8347&highlight=mustang+steering ... or do I just need to position the box to fit the pitman arm to the angle of my steering arm?
Is this too many questions? It's been a looooooong day and I may be able to score a great bed with the steering box. I hope this thread can clear up any question with other new rodders!
Thanks in advance,
Kelsey
Thanks in advance,
Kelsey
