Rainman:
I used a G-body clip - not sure they are the same as the Camaro, but close.
I installed a 66 Mustang repro radiator. It was the only thing that I could find to fit next to the P/S box. Go back a page and there is a picture of it. I had to use a electric fan since my motor sits so low. The 1x1 bar in the above pic is where the original radiator support is located. I had to push the radiator forward about 4" from that and also sideways about 4" to clear the P/S box.
Keep in mind, I lowered my body several inches on a Z'd frame, so I had to cut my original rad support shorter and also notch it around the P/S box.
If I did it again, I'd try a rack & pinion.
You should at least have the fenders/grille in position before you place the radiator.
Did you ever get pictures to upload?
Had it to a couple local shows this year - Hooters and the Flying Eyeball. I hope to get working on it a lot more after the holidays, so maybe you can stop by and have a look see then.
...and welcome to RRR!
