Old 08-24-2021, 10:58 PM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
I have a '91 Ford truck with 'semi' dual exhaust like yours, just the back half. It has a 5 litre, [Windsor 302, mostly] V-8. It looks like it has duals and it sounds like it has duals. You'll be just fine with that set-up.
Old 08-31-2021, 04:24 PM
I-R-POPS's Avatar
I-R-POPS I-R-POPS is offline
''Rusty Mopar Slacker''
Default Progress.......
After a week of tomorrows I finally got the exhaust finished up.
Too many other irons in the fire.
Next up is to convert the in tank fuel pump to one that will supply the TBI
with the right pressure and a return line.
Old 08-31-2021, 05:24 PM
Torchie's Avatar
Torchie Torchie is offline
Old 08-31-2021, 06:03 PM
05snopro440's Avatar
05snopro440 05snopro440 is offline
Originally Posted by I-R-POPS View Post
It will work I'm sure. I considered running duals on it but room is too tight under this thing.
On my 46 both pipes go to the passenger side like yours, the mufflers are standing upright, and then proceed to the back. Full duals, but it makes it real easy to put in an H-pipe. You have a bigger trans and crossmembers and a transfer case, but it looks like you have room to do duals if your heart was set on it.
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
When you don't know what you're doing, it's best to do it quickly.
And when Iím gone, you can call me foolish but hopefully not boring. I will have lived.
The more I learn about women, the more I like my car.
Old 09-01-2021, 09:15 PM
I-R-POPS's Avatar
I thought along those lines for a minute. Then I decided for what I have planned for this thing it wasn't worth it. KISS is now my middle name.
Old 09-01-2021, 09:43 PM
Sunnybeach Sunnybeach is offline
Nice work.
Old 09-01-2021, 09:53 PM
I-R-POPS's Avatar
Originally Posted by Sunnybeach View Post
Nice work.
Thank you. It's coming along.
Old 09-01-2021, 10:13 PM
I-R-POPS's Avatar
I found out the fuel pump for a 2006 Dakota has a 80psi max pressure with a 58psi system pressure which is perfect for the FI Tech TBI. With a slight modification to the mounting flange [cut the locating tab off] I was able to use the plastic threaded tank nut from the 1995 donor tank.
Installed a return line bung fitting and a vent/roller valve fitting in the top of the tank.
A second 60 mile round trip to the big city for more 6an fittings and a few minutes in the morning to finish plumbing the lines, install a pressure gauge and I have it made.
I'm thinking I might be ready to fire this puppy for the first time by the end of next week!!!
Old 09-02-2021, 06:00 AM
BillM's Avatar
BillM BillM is offline
First class work POPS, everything looks great.
Old 09-02-2021, 07:44 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
