[cl [cl [cl [cl [cl [cl
[P [P [P
[P [P [P
Good job [cl
It's nice to be able to swap
That's cool, great deal.
[P [P [P
gotta love a woman who gets into it such as Mrs Pops, cool project too ! ..
cant believe the condition of the cab,, or the rest of the pick up .. good score!
and good bargaining on the sign nice one!
Looking great, pops!
We got the tires mounted and made the 1st of many body to frame mounting attempts. When I set the cab in place with the front tires in the wheel wells where I want them, I was surprised to see there was 12" from the distributor to the fire wall and no room for a radiator.
Sorry no picture. When I saw that I just set the cab back on the table.
Some serious fab work in the future to cut 6" out of the wheel base length, relocate the engine mounts and make body mounts.
The rack and pinion steering is going to be a time saver for sure.
[P [P [P [P
A lot of guys don't realize until they try a swap that those "mini" pickups from that era have the firewall a lot further forward than the older truck will. I've seen a huge number of guys doing an S-10 frame swap buy the V8 motor mounts and then be astonished when the engine is much too far forward.
On my 46, I moved the motor mount location back about 11" from the S-10 location and could have gone a couple inches more.
It's looking good, though. On mine, building all those mounts took 2 weekends (and not all of them), so I'm sure you'll have it done in no time [cl
been there! i like fitting the stock fan so I moved the first one back 6 inches (no fan) the second one 7 (barely fan) the third 8.5 (great room for fan) and the last one ~9 and the lower rad hose gave me fits hitting on the frame. so on this one I moved it 7.5 to keep the fan as close to the rad as possible and lots of room for the lower hose.
I mention these trials to say, make sure you know where everything is going to end up. with a 9" move there was amazing room in the engine compartment but the diz cap barely installed and the lower hose was a punk about it. said another way, if you have 13" great, but maybe you will only get 10 of that.
also most recently I shortened a frame and just welded stanchions to the frame on a level floor and after cutting in half it only changed vertical height on one side by 1/32. way better than my previous way of putting the truck on jack stands, that was a real **** show. the whole length change took less than 3 hours.
looking great!
That's a nice, precise splice, Pops
