1925 studebaker project
I didn't get a chance to take any videos sorry, been working crazy overtime and its been hard to keep the updates coming. Got my harness and pcm in from LS Connection and it turned out great! Also grabbed a waterpump that should work out the best for my set up...needed on that had the outlet as close to the driverside as possible cutting down on a longer radiator hose. My new tri flow radiator from eastwood had to be modified just a bit to fit in the shell behind the old radiator, but it ended up working out great. We had to move the bottom outlet up about two inches so the bottom rad hose would clear the airbag crossmember. Engine and trans are back together again and there set in place with motor mounts and trans crossmembers getting mocked up. engine sits low enough for me to run a hood when everything is said and done.
    64.3 KB
    107.4 KB
    126 KB
    134 KB
    47.4 KB
    128.1 KB
Should have my alternator bracket and corvette crank pulley from ICT billet in this weekend as well.
    113.9 KB
    118.9 KB
    90 KB
    161.9 KB
    102.9 KB
Tow package!
My wife and I snagged this sweet 58 serro scotty camper. Plan is to bag the camper and tow it with the car so we added a tow package over the weekend.
    53 KB
    225.7 KB
    223.9 KB
    53.6 KB
    46.3 KB
    91.3 KB
    59.1 KB
    79.3 KB
    74.9 KB
body is off once again to get most of the final welds done on the frame. i didnt really like the brackets i got from speedway for the wishbone ends, they seemed kinda cheesy so Willis welding and fab came up with a new design for me. These are way more solid and will blend in perfect when the body is on. Tie rod is on and we also added a dual "cold beer intake". Still has to be trimmed a bit, there will be about a 2" gap between it and the rad.
    78.8 KB
    82.6 KB
    59.5 KB
    74.3 KB
    73 KB
    81.2 KB
    78.1 KB
    92.6 KB
    104 KB
    64.8 KB
Couple more pics of the new brackets for the wishbone rod ends.We also decided to change the motor mount design.
    70 KB
    79.7 KB
    62 KB
    72.7 KB
We made some modifications to the fuel cell and to the ThorBros watts link kit. We added tube connectors so it would be easier to remove if we needed to get to the fuel cell or rear diff. Car is back on all four again. waiting on some parts for the fuel system and some end caps for the custom air tank that will be hidden next to the rear kick up of the frame. Should be having a decent amount of updates in the next few weeks.
    101.9 KB
    54.6 KB
    16.1 KB
    47.3 KB
    56.4 KB
    113.2 KB
    173.2 KB
    118.1 KB
    137.4 KB
    108.3 KB
Willis Welding and Fab has been on fire working on the car the last couple weeks, huge thanks to my buddy Geoff, I would have threw in the towel a long time ago if it wasn't for him!
    143.9 KB
    109.9 KB
