Cool! Nice to see some progress [P
Thanks Snopro, I put another 3 or 4 hours in today extracting the engine.
Here's some pics I took along the way:
I brought a BBC exhaust manifold along to compare the spacing of the ports with the RR. My plan is to buy a set of headers for a BBC in a roadster and then cut the mounting flange off the pipes. Then I'll make flanges and weld the pipes to them. I think this'll be easier than a set of weld up headers because I won't have to mess with welding the collector. I guess I'll just need to decide between zoomies, lakes or something else.
Here's a picture of the end of the speedo cable. It amazes me the amount of material and that it's brass and was hand turned on a lathe.
Here the best shot I could get of the mechanical power brake servo and it's actuator linkage going to the master cylinders. These things are so cool! Invented in 1919 by Marc Birkigt, RR used them into the late 60's. "The servo is very similar to a clutch, and driven off the side of the transmission. Pressing on the brake pedal brings the other face of the servo disc in contact with the driven face, essentially like slipping a clutch. That generates a variable degree of force, which here is transmitted to the master cylinder." Unfortunately, I doubt I'll be able to use this on the 27 roadster because of limited space.
This is the linkage that hooks the go pedal to the transmission. I snapped it because it's so figgen complicated. I've heard that getting a 4 speed hydromatic to shift correctly can be a tedious task. Between the amount of intricate linkages and over sized fasteners on this car I honestly believe you could melt it all down and have enough to build a Toyota Corolla!
Dual Points!! Vroom Vroom
Coil tensioning devise. Somebody's rolling in their grave.
Tomorrow I should be able to lift the engine out of the car.
