looking good.The pipes were a good call
Moving along nicely. Thanks for sharing your project.
Excellent work! I got to work on a 29 Essex once. A guy came in wanting to install a toggle light switch since the column mounted switch wouldn't work. He finally decided to let me replace all the wiring, so I ended up doing the whole car with original looking cloth covered wire. The funny part was when he handed me a complete original wiring diagram and said "I don't know if this helps or not".
I appreciate what you are doing and how you are doing it. You are getting a very good result even though you are using caveman techniques (like I do).[cl
Agree with above^^^^ [cl[cl[cl
Looking good man. Almost looks easy in the pictures.
Looks great [cl
Recycling is good rusty or.not![]()
Looking good. I'm at the same stage with my build. I looked into buying a press brake but the cost was prohibitive so I ended up making one myself which turned out to be rather easy. If your interested let me know and ill send you a few pictures of it.
hey dozer this is it . I got a 20' piece of 3x3 1/4 cut it into four pieces welded two together and used the two others for the clamp and the part thats hinged. I did grind the edge of the clamp one to make it square instead of rounded. I used some commercial hinges but I've seen people make there own. all in all I got less than $100 in it and it bends pieces up to 50'. That piece of sheet metal was the first bends I did with it
Leave it, It looks okay. After a while you won't even notice it.
Glad to see you are on your feet and you got the engine fired.
