endicott_jb
Yesterday I started off with modifying a trailer jack to work with my pipe bender as there’s not much room out in the shop. Works pretty good for a $40 jack. Then it was on to bending a piece of tubing for the column support. Got it finished and welded into place. Used the original column support as a mounting plate and used a u-bolt to hold everything tight. Then because the ol’ lady kept complaining about not having anything to keep her feet from sliding, bent another piece of tubing and welded it to the passenger floor board. Today, I made a new gas pedal mount and welded it to the kick panel and I think it will work well. I will have to see how well it works after my new throttle cable comes in. After that, drilled the holes for my headlight swith, the shutoff cable, and attached the turn signal assembly. I think I finally got it to where the cable will kill the engine and still allow the throttle to work properly. Tomorrow, I hope to tackle the cooling system. I’m thinking of just removing the thermostat and seeing if that solves my overheating problems. There’s also a coolant pipe that rubs against the driveshaft just slightly enough so I need to bend it to the side a bit. Then, because I have been noticing a major amount of leakage on my air system, I’m going to go through and make sure all the fittings are tight and leak free. If I can get all that done, she’ll be pretty much ready for the road minus windows and door panels.
