Sometimes I don't get a lot of forward progress, just sideways progress, but here's a little more steering linkage engineered.
Doc, I haven't forgotten about the Mustang two geometry. [one] I needed to build up some personal momentum for the project after that long recess so I started on something that is nicer to do. [two] I wanted to engineer the steering shafts with all of the stuff packed in there, engine, header, starter, and pedals, so I can weld up the heim joints pedestals, when I take the motor back out to weld up the top hats. [three] I was stalling a wee bit on cutting out the top hats on the suspension, due to being annoyed and scared. After doing some more homework I did finally see that the top hats are eccentric and welded on the wrong sides, but welded beautifully, [he was a really good welder, he still should have had his thumbs yanked off].
I'll have to look those top hats over more closely, the last picture looks like if I swap sides I'll only move the top of the spring back a bit and not the mounting holes for the top A-frame, --hmmmm.
