TruckRat
Looks great and I like the trailer!
Lookin' good. Sounds like you have some great tools to go with your skills.We started reskinning the lower part of the driver door...
Before welding, we are on the fence about using our new tool ''the perfect panel prep tool'' from eastwood. Anybody use one? it creates a tiny bend on the edge of sheet metal - so when you line up two pieces of sheet metal, you have a 'valley' to weld in instead of on top of two butted pieces. Thinking that would work better and help keep it from distorting too.
The tool sounds like a good idea. It would logically leave you with a flatter weld. But, I doubt it will prevent distortion. At least not much, if any. Only keeping the heat to a minimum will do that. The conventional wisdom is to use short welds, and move around a lot, allowing each area to cool before revisiting it.
But you probably knew that already.![]()
Congrats! This thing looks and sounds great, i really like your color choice on the dash. [cl
-Chris
yes, the details are so appealing, everything is square square square nowLove the little details of the trailer. Things like that are gone forever...
The dash looks super nice.
