Skip
I love the custom touches we do to make our rides our own. Nice work.
I think I've heard similar comments at a poker table. Very nice body work there young lady. [clso, Brian ended up being able to weld up those pinholes in the hood without too much trouble, whew! Got it epoxy primed, so no more bare steel. They are wavy as heck and have some creases in them (from the hinge not working smooth I think), don't know what we can do about that
The nose cone has been a challenge. After sandblasting off the who-knows-what paint (I think there was POR15 on it), and cracked body filler, I was left to redo the body filler (which is pretty new to me, but I am not one to back down from a challenge).
so, she went from this (after sandblasting):
to this:
to this:
to this, yay! (SPI epoxy primer)
Now, after the epoxy primer, I can see where there is pitting in spots that didn't need bodywork. Do I need to fill the pitting with putty? Or will a 2K primer fill the pitting? I was probably going to use SPI 2K primer (then epoxy over that as suggested by SPI), but maybe it might not fill enough to get rid of the pitting? [S
Progress is slow, but we get closer all the time. Today, I picked up our sandblasted/powder-coated front wheels and got new double coin tires on them! We will get these tires on the rear (dually) as well (after these are paid off, ha!)
I meant to share this too - we dragged this little gem out of the weeds weekend before last. She will be coming home soon (we need to find a way to tow it because it has a VERY RUSTY inverted 5th wheel that is probably not functional anymore (the inverted 5th wheel means a kingpin on the tow vehicle, which when engaged, makes the landing gear pop up). We think we are going to weld a kingpin on the trailer and tow it with a dolly, but we cannot find a dolly to rent! (We can tow with the log truck)
Most asked question about acquiring this trailer? ''What are you going to do with THAT?'' Haha. Not everybody ''gets it''. We will put a modern axle under it, make a step in the front end so the body sits lower (tubs inside). Maybe a camper? Or toy hauler? Who knows....
If you don't have to go very far, you might rig a way to pull it with a flatbed goose neck type hitch
Yes! I can't wait - lowered (tubbed and rise cut in the front), matching wheels/tires to the Diamond TWe get it!!! It'll look kool tagging along behind that Diamond T!
You should be able to get a wrecker to tow it for you. I've seen them tow some trailers in awful shape before. Keep the speeds down and the tires should be ok if they aren't already separating. Or put it on a Landall Haulall trailer, kind of like a roll back for big trucks and trailers, the axles slide forward so the rear deck can touch the ground, making it a drive on ramp.
I've fooled with trucks and trailers for the last 40 years and have never came across an inverted kingpin set up. Must be from the 30's or 40's.
