1936 ford P/U unibody build
windshield post... post
got cutting on the post today The dots where the intended cuts
Slightly modified
In a earlier post I showed the piece of 18 gauge rosette welded in. This helped with the alignment and some strength.
The turnbuckle helped pull it all together
windshield post ...Post ...Continued
Took some 18 gauge to add some strength. tacked it to a piece of tig wire to get it in place.
Top view of alignment.
the 'inspector" says it looks OK.
windshield post
just a little side note when you get into an area that is a leaded joint make sure you get all the lead out of where you intend to weld as it will cause great problems in getting a good weld. The lead was located at the top of the cuts.
A SPECIAL thanks to Dan (the truant) for the help with the windshield post!
WORDS TO LIVE BY I KNOW I DO
Thought I was registered here...guess not...anyways, I am now. :cool: Looks like it welded up fairly nice....now on to the next side :)
update
finished up the right side and started filling the area across the top of the cowl
Dash installation
The Chevy dash got the nod. Dan, the truant stopped by and helped out with the installation.`Great job Dan.
The next trick up the the sleeve is to figure out how to incorporate cowl steering (would like to use a reversed covair box) and a hanging brake pedal.
going to be running an automatic in this truck so only need to get one pedal up in the same area. Does anyone have any pix of that combo? Any suggestions would be great. Thanks in advance, Clipper.
Great looking truck and killer skills. I can hardly wait to see more progress! Dash looks great. How`re you gonna be for leg room?
Very Nice !!!
Very nice work and some really great tips.... :cool:
Thanks for sharing with us, looking forward to seeing more... '22
