vintageT
Banned
I wish I had your skills.... Now I have to go find this other build of yours to look at as well!
I got my gas tank mostly built. It's built from 18ga. steel, has 2 internal baffles to control slosh, 3/8" pickup and 5/16" vent, 2" fill pipe, capacity is 20 gal. IMP or 24 gal. US. The sender hole has a dummy plate on it so I can pressurize the tank and check for leaks.
Search 1934 Cadillac in the builds section.I wish I had your skills.... Now I have to go find this other build of yours to look at as well!
Good one [cl[clHey ZZ , with the legs on that gas tank, you think it will still fit in the car? [cl. Nice work!
It'll mount directly under all the junk in the trunk, inside the frame rails.Nice work on the tank! You make that look way too easy... Where's the tank going to be mounted?
The dash on this car had been gutted so rather than tracking down all the original parts and trim, I cut it out completely and started fresh. I wanted to make something different and give it more "Packardness", so I made a small center grille frame with a distinctive Packard profile and started building the dash from there. The side panels will be removable for access and I plan to finish it off with a stainless grille insert. Once I get some seats mounted, I may also make a small console to tie into it
I like the dash idea. The Lincoln Zephyr waterfall is one of my favorites. This has a whole lot of that in it, but tweaked to a Packard [cl[cl[cl
