Dr Crankenstein
We worked on the trunk lid yesterday.
We built some brackets and bolted them to both lower corners, where the original lock/latch hardware belongs...
Then we cobbled a pair of "tensioners", using the threaded portions from a set of cheap stabilizer jacks we had kicking around...
Pressure applied. We added tension, hammered a little, added tension, hammered some more, eventually working out a sharp buckle in the structure and some light pressure points on the skin...
Above, we had to apply some heat and another cobbled device to help pull the buckle out. (No pictures of the device, sorry.)
Closed the lid and it fit bad, really bad... but we still had a ton of pressure on it. We removed the tensioners and closed the lid again... hot damn, it's nearly perfect!
Before...
After...
Before...
After...
Remnants of paint and primer deceive the eye and actual fit. It's better than the pictures show and we're very pleased with the results. The other side still needs some work, but it's close and should work out just as well...
Before...
After...
Before...
After...
