Starting to look like a cross between an Auburn and a Duesenburg. The door swoop on the Duesy might be more fitting?
Yeah--the Duesy is closer to the profile that the Bentley body offers. It is a little flatter and squared where the Auburn body is more swooping.
There is a little issue with the cockpit structure where it'd be a lot easier if I left the tail higher at the doorpost, and raised the tail to achieve the contour you produced. Then come back from the windshield appx. 3" and scallop the door top down to about 1/2" above the botom edge of the molding and cut it back to the tail. The end of the cockpit is appx 9" back from the rear door post and the top edge is the 1"x3" crossmember, thats where the cross body trim would lay. That would leave the drip rail and botom door molding and hood trim in a line to tie the body together.
My pic is going downhill a little, but the car is really close to flat, maybe a bit nose down. Most speedsters were flat to nose high, and I will most likely rase the front up 2" or so-- It has a Dodge PU frame with cut springs, and I have a fresh pair of springs to put in to raise it up pretty easy..
This weekend I hope to build the tail structure with 1"x1" and make it a stand alone unit like a car hood. I think the long frame is going to be pretty flexy, and I want the tail to give a little. That may mean a body cut line about 1/2 way up the 'rear door' area.. Not too fond of that idea, and I may use some dezus fasteners for the tail side panels like stock car bodies so I dont have the cut line.
Thats a sweet duesy pic--heres an Arburn pic to compair & the PSd Bentley project-- Not exactly a multy million $ car like the other two, but for the $2500 I estimate to have in it so far--and a little more tweeking, it'll make a jalopy version.
It takes alot of nerve to put this thing in the same post with those two cars--doesn't it.. I ain't got no shame---
I'll get it closer....Thanks for the interest.. Later
PA41
