I pulled the drive train back out so I could make the rack and pinion mounts and box the frame where I notched it. When I did this swap on my 48 I bought some tie rod adapters that adapted Ford Explorer tie rods ends to the Cavalier rods; this time I figured I'd just make some. There was already an adapter that screwed into the Cavalier tie rod so I cut the end off of the Plymouth tie rod, ground the adapter down so it would fit inside, welded it, and put a tie rod clamp on it. With the Explorer tie rods you had to re-size the steering arm taper; this way I can just use stock 49 Plymouth tie rod ends. Now I need to patch the trans tunnel where I cut it, and take it all back apart to clean it up and paint it.
