falconvan
Looking good. [cl you'll be driving very soon, fast i should think[S
It should do OK although it is basically a low compression smog motor with some porting and a few bolt on goodies. It'll be plenty for what I want to do which is cruising the car shows and a few smoky burnouts.
I got the alternator brackets made; I decided to go with a GM alternator so Id have an internal regulator. I also pulled the fuel pump for the SHO motor out of the tank and replaced it with a straight 3/8" line and will mount an external pump. As soon as i get the fuel line run and the pump mounted, it should be ready for a short test fire.
